Located Gold Coast will freight all parts auswide
Gearboxes r32 push type $500
R32 pull type late model $750
R33 pull type $800
R33 converted to r32 manual speedo drive and push bell housing $850
N1 headlights with grill brackets $500
-5 twin turbos $1600 only 1200km use absolutely perfect cond.
Dash pad $160 perfect demister vents no ac vents (passenger and middle vent available for $120pair) or $260 the lot whole dash VGC
Gtr fuel tank plastic with walbro pump and sender $200
Cluster surround and working clock $180
Drivers door switch $70
Centre gauges $70
Steering surround $20
Telescopic part $20
Twin turbo pipe in black both pipes and hose $100
Abs $150
Latch and support with horns $70
Stainless dumps brand new $100
Mines stainless dumps and front pipe $600 3" bell mouth type
Rear seat good cond. $100
Rear subframe $100 bare
Spare wheel $50 genuine jdm r32 gtr
Rear door cards $100 pair
785cc injectors billet rail Turbosmart reg with -6 braided line $500
Textured stereo surround $80, ashtray $40, manual surround $40 boot $10 or $180 the lot
Drivers window relay $50
Heater vent actuators $50ea both available
Gtr r32 brakes and cross drilled rotors $200
Plenty more parts available preferably text or call to discuss 0414596256 more photos available also
post-44496-14240410126628_thumb.jpgpost-44496-14240410293949_thumb.jpgpost-44496-14240410570334_thumb.jpgpost-44496-14240410737196_thumb.jpgpost-44496-14240411098878_thumb.jpgpost-44496-14240411281251_thumb.jpgpost-44496-14240411425313_thumb.jpgpost-44496-14240411664365_thumb.jpgpost-44496-14240411922718_thumb.jpg
https://www.sau.com.au/forums/topic/453896-for-sale-r32-gtr-wrecking/
  • Replies 40
Is the textured stereo surround in good condition with no cracks or scratches and all clips?
Can you send a pic?
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
