Located Gold Coast will freight all parts auswide
Gearboxes r32 push type $500
R32 pull type late model $750
R33 pull type $800
R33 converted to r32 manual speedo drive and push bell housing $850
N1 headlights with grill brackets $500
-5 twin turbos $1600 only 1200km use absolutely perfect cond.
Dash pad $160 perfect demister vents no ac vents (passenger and middle vent available for $120pair) or $260 the lot whole dash VGC
Gtr fuel tank plastic with walbro pump and sender $200
Cluster surround and working clock $180
Drivers door switch $70
Centre gauges $70
Steering surround $20
Telescopic part $20
Twin turbo pipe in black both pipes and hose $100
Abs $150
Latch and support with horns $70
Stainless dumps brand new $100
Mines stainless dumps and front pipe $600 3" bell mouth type
Rear seat good cond. $100
Rear subframe $100 bare
Spare wheel $50 genuine jdm r32 gtr
Rear door cards $100 pair
785cc injectors billet rail Turbosmart reg with -6 braided line $500
Textured stereo surround $80, ashtray $40, manual surround $40 boot $10 or $180 the lot
Drivers window relay $50
Heater vent actuators $50ea both available
Gtr r32 brakes and cross drilled rotors $200
Plenty more parts available preferably text or call to discuss 0414596256 more photos available also
post-44496-14240410126628_thumb.jpgpost-44496-14240410293949_thumb.jpgpost-44496-14240410570334_thumb.jpgpost-44496-14240410737196_thumb.jpgpost-44496-14240411098878_thumb.jpgpost-44496-14240411281251_thumb.jpgpost-44496-14240411425313_thumb.jpgpost-44496-14240411664365_thumb.jpgpost-44496-14240411922718_thumb.jpg
https://www.sau.com.au/forums/topic/453896-for-sale-r32-gtr-wrecking/
  • Replies 40
Is the textured stereo surround in good condition with no cracks or scratches and all clips?
Can you send a pic?
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
