For sale
Gold Coast 0414596256
Pair of z32 afm's with modified plugs to suit direct plug in with no plug wiring necessary
$350 pair
I've opened one up and confirmed they are genuine, removed from running rb26
post-44496-14242288420701_thumb.jpgpost-44496-14242288692048_thumb.jpgpost-44496-14242288895913_thumb.jpgz32'spost-44496-1424228801696_thumb.jpg
no there are actually a range of fake ones out in the marketplace now that are very similar, I've come across them myself. Only way to be certain is check inside :)
Hi mate, it might be useful to somehow prove it still works, as I bought used NISMO afms and when I plugged it in for tune, no voltage was going through and its now useless to me. Not suggesting your a liar or they dont work, just reassuring when potential buyers see it works 100$ :) Just a tip.
GLWS
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
