Living on the North Shore isnt meant to be "exciting", its mainly a residential area afterall, but as mentioned there are still plenty of places such as crows nest hidden around which offer more funky eateries, cafes etc than you can poke a stick at.
St Leonards is not a bad place at all, very close to the city, easy transport, low crime rate etc.
https://www.sau.com.au/forums/topic/45428-st-leonards/#findComment-926091
Ok these guys are right but...
It's boring as batshit.
I felt like I was in a coma for a year and this story is how I characterise the area:
I caught the train home one day and the station staff were on strike so the cattle drafting things you go through after putting your ticket in were stuck open. I was reading Brave New World as I walked up the stairs so I was one of the last people up there to the cattle drafting things. I looked up to notice that they were open and then I witnessed the most amazing thing.
All the good and decent St Leonards people walked up to the gates and tried to put their tickets in to be validated but since the machines were off to keep the gate parts open, they had no power to accept peoples tickets.
There was mass but restrained and quiet confusion as people tried to work out the significance of the ticket machines that wouldn't accept tickets until eventually some of them noticed that the little gate 20cm in front of them was actually open and they could just walk through unimpeded.
The first few people went though but the second row of people hit the gates with the same confusion.
"Why isn't this gate accepting my ticket? I have to put the ticket in to open the gate..." etc etc.
Once this row figured it out and went through the people behind had no more problems because they were now following the crowd.
I stood there thinking, "Aldous, you may have been a bipolar drunkard with no more than two good books in you but you really had some amazing moments of clarity."
https://www.sau.com.au/forums/topic/45428-st-leonards/#findComment-926339
you're always on your toes ready to dodge bullets if required...
To be honest I can't remember the last shooting, they aren't in my area anyhow. If at all they are about 15mins East at Mt Druitt (the ghetto).
Although I did hear on a police scanner the other that some weirdo stabbed a chick up on the hwy and was walking around with a knife and a bloody shirt.
No crime in my neighbourhood, I think it is because 99% of the out-of-towners would get lost in my estate and would never find their way out :D
https://www.sau.com.au/forums/topic/45428-st-leonards/#findComment-927313
http://www.domain.com.au/UserServices/subu...l&PostCode=2065
The above link will give you a good snapshot of the area from a home buyers perspective..
My opinions of the area (having worked there for 6 years)
Upper class well established mid northern suburb of Sydney with a increasing multicultural population. 5 train stops from the City on the main Northern Line it is a very large business and commercial hub.
Recent increase (over last 5 years) of larger residential towers of over 5,000 units has seen the area expand very rapidly over this period. Rental rates are very high, and it's more of an area where 25-40 year old professional singles would live and not so much an area where there are lots of children growing up.
Free standing Houses are older style, circa 1950's style double brick and off street garaging is not very common except in the newer unit complexes. Chatswood is the closest Major Retail area (Westfields/Myer/Grace Bros etc) and is two stations further North.
https://www.sau.com.au/forums/topic/45428-st-leonards/#findComment-928560
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
