Hey, Hey its on again, Drift practice and come and try day on the 1st of August.
This day will be set-up so that those who would like to learn and spend time on the track with LIKE minded people can do so without pressure from other drivers. Splitting the entrants into either 2 or 3 groups, experienced, intermediate and beginner. Let me know what YOU think. Any intrest in a car setup night or two before hand?
The cost will be $70 per entered car (whole day) there will be between 30-40 cars allowed for the event.
PLEASE SUPPORT THIS EVENT AS FUTURE EVENTS AT MALLALA HINGE ON THE SUCCESS AND SUPPORT YOU GIVE THIS ONE.
1ST AUGUST MALLALA
entry forms will be posted up soon
EMAIL QUESTIONS OR SUGGESTIONS TO [email protected]
https://www.sau.com.au/forums/topic/45432-drift-mallala-1st-august/
  • Replies 44
1ST AUGUST MALLALA
Dont want to sound negative here Trent, but werent the 4500 spectators Mallala got through their gates - bigger crowd than the Konica cars - enough to show the organisers the potential of the sport?
Surely a properly run event like the PSi day has to have more clout with Mallala than a come and try event?
Has anybody got a spare couple of rims I can borrow?:P  Might have to start bugging used tyre mart too.
Bl4cK32, if she aint run in, borrow Dean's car!
What size rims are you after Steve? Depending on how busy I am, I have a set of 17's that I am going to paint up, but if I haven't started it by then you are more than welcome to have a lend of them - 2x 17x7 and 2x 17x9
Chris
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
