hello there ladies and gentlemen, im new here, I have a few questions for you guy's/girl's. does the rb20 cylinder head bolt onto the rb26? The story is im doing up an a 1965 xp ford falcon and instead going the v8 route I would like something different, like putting in a turbo rb26. The way the rules and regulations are I can either put a non forced induction engine upto 5 litre or go forced induction upto 3 litres. So any advice an help on what to look out for on the rb series engines would be fantastic thank you
https://www.sau.com.au/forums/topic/454394-newbie/
Well to be honest I don't know if they will fit - probably with a bit of work but its one of those why bother things.
Not sure that many people would have ever tried but RB25/20's & 25/30's exist so you would think you could get a 20 head to fit on a 26 if you really tried.
But:
The Rb26 head is a pretty good thing and given that most RB26's fail in the bottom end I would recommend you go looking for an Rb26 head.
As for the flow thing, no.
The car a 2 or 4 door?
https://www.sau.com.au/forums/topic/454394-newbie/#findComment-7490356
4 door xp sedan, thank you djr81 for your reply. the aim is have something different with reliable horse power, and drivable , few of the ford falcon boys are a bit upset, reckoning im ruining a classic car and ricing it up but ive nothing but good things about the rb series engines that they make good reliable horse power, the power im chasing is around the 350 to 400 mark the car doesn't weigh that much so it would be a fun car to drive around
https://www.sau.com.au/forums/topic/454394-newbie/#findComment-7490813
Yeah can understand why. Wouldnt an XR6 motor out of, say, an EB be better?
Honestly having owned too many GTR's and RB26's they really aren't as brilliant as people make them out to be. I don't know that I would recommend one for a conversion. Not least for the reason that (From memory) the exhaust is on the wrong side for a Falcon.
https://www.sau.com.au/forums/topic/454394-newbie/#findComment-7491970
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
