hi guys
im sure this has been covered countless times, but i got some funny reading and im just after a second opinion
Compression test values are as follows:
DRY TEST (no oil):
1 - 110 psi
2 - 105 psi
3 - 105 psi
4 - 100 psi
5 - 115 psi
6 - 100 psi
WET TEST (oil dropped in cylinder) :
1 - 120 psi
2 - 125 psi
3 - 105 psi
4 - 195 psi
5 - 150 psi
6 - 160 psi
the wet test threw me off about with how much variance there was, but as well as that it seemed quite low on the dry test
thanks in advance
cheers
ohh i forgot to mention its my mates r33 im looking to buy
just wanted to do a check before i commit....as far as i know it runs pretty sweet
Edited by stagea_1998
Why did you test it? Any problems?
If not just drive it. People get caught up and just confuse themselves with comp tests.
if it runs well and doesn't blow smoke, don't worry about it.
btw does it have standard cams? the number are low but cams can affect that (and also the exact testing procedure of course(
nah all standard internally theres just a few basic bolt ons
im pretty well inclined to say its fine but i always like to have a second opinion when im unsure
Re The testing procedure - figures do not seem consistent (bad or good) - Dry V Wet variances. Readings on some are all over the place.
I'd have some one else who does this often re-test first. It's just too inconsistent.
Eg. cyl 4 has jumped 95psi
Variances
10
20
0
95
35
60
thats what i thought ...its a massive jump!!
i did use a second tester to check as well after i saw that to confirm the reading and sure enough it was dead on
ive done plenty of comp tests over the years on cars me and my brothers have bought and with the same test procedure id get pretty consistent readings...so id say ive an idea what im doing lol
this ones thrown me though....
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
