Hello
The time has come for me to replace the coilpacks on the 25de. I'm not keen on spending big bucks on genuine ones and the aftermarket are still quite a bit.
I'm curious if a waste spark system would work well on a stock 25de as that's my cheapest option. Obviously the car is still on stock ECU and the dwell time won't change, what happens to the spark in this situation? Is this a route I could go down?
The car will see track days and a turbo at some stage.
Just after some advice, cheers
https://www.sau.com.au/forums/topic/454557-coilpack-replacement/
If you can't change the dwell through some aftermarket ECU solution, then best to stick with a stock replacement. OEM, splitfire, whatever.
I assume youre looking at ECUs if you're turbocharging the vehicle? If so then you could try an LS2 coilpack conversion. Even then splitfires make an easy drop in solution, depending on how much boost you want to run.
In my neo with less than 15 psi boost and ls coils they were fine at stock dwell . sorting the dwell fixed the spark issue at higher boost.
For an na Ls coils will be fine on stock boost. (Get it. No boost. Whatever, stock dwell and stock boost is fine, therefore stock dwell and no boost won't misfire ,)
Correct me if I'm wrong, but you can't have a waste spark ignition on a stock ECU. The ECU fires the spark, and it fires them one at a time, not in pairs.
You are wrong. It can be done. It's not the best option though. There's a guide somewhere in the net.
Thanks for replies guys, I was afraid I'd have to fork out big but looks like Splifires it is.
I'm not changing ECU until I turbo the car which is down the line.
The issue with wasted spark on stock is not the firing signal (just a matter of wiring the pairs), but the dwell time. Would the spark be weaker by about half as it's proving spark for two cylinders?
What kind of "wasted spark" are you talking about? If you have a single ignition output driving 2 coilpacks, like OEM or splitfires, then there is no degradation of the spark, it simply means that each coilpack is firing twice as often (one spark being "wasted" on the exhaust stroke)
One caveat would seem to be the difference in duty cycle between wasted and fully sequential ignition, especially when you start increasing dwell. Then there could be an argument about additional heat and the negative effects on the coil.
I run splitfires in wasted spark configuration, with 2ms of dwell. Although its perfectly fine on 13psi of boost, longevity of the coils is something on my mind. (hence keeping the dwell time down)
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
