Consolidated everything - mudflaps added. Will be adding other bits as I come across them.
GTT Nistune package $450 – everything you need to get the most out of your bolt on mods. Never got around to installing this in my car, but all parts were purchased in working order.
R34GTT Manual ECU
Type 4 Nistune board and cable
Turbotech manual boost tee
Blitz 52mm mechanical boost gauge and cup
https://www.dropbox.....48.21.jpg?dl=0
R34 plastic eyelids $60 – in sonic silver. Slight bend in one as per picture, does not affect ‘performance’. Affix with double sided tape.
https://www.dropbox.....22.57.jpg?dl=0
R34 coupe front and rear standard bumper $90 for both – in sonic silver. Front bar is off a GT so no SMIC vent. Both in good condition with a few scratches from being in storage
https://www.dropbox.....21.30.jpg?dl=0
R34 GTT stock wheels $150 – gutter rash on most of the wheels. Some rubber ok, some not.
https://www.dropbox.....35.29.jpg?dl=0
https://www.dropbox.....33.20.jpg?dl=0
https://www.dropbox.....34.30.jpg?dl=0
https://www.dropbox.....35.23.jpg?dl=0
R34 GTT stock coilovers $50 – cracked dust boots, came out of car with <100thousand k’s and were working fine
R34 GTT stock front indicators and side repeaters $50
https://www.dropbox.....23.28.jpg?dl=0
R34GTT Stock airbox and snorkel - $80
R34GTT AFM (pink label) in working order - $70
R34 Coupe full set of Nissan moulded mud flaps in Sonic silver - $100 (pics to come)
R34GTT Manual ECU $100
Type 4 Nistune board and cable $280
https://www.dropbox.com/s/zltyv6tx49ptvz6/2015-03-30%2020.48.21.jpg?dl=0
Turbotech manual boost tee $15
Blitz 52mm mechanical boost gauge and cup $40
R34 GTT stock wheels $150 – pics of the worst of the rash. Some rubber ok, some not.
Edited by sonnyQ
Bump, prices amended.
Type 4 Nistune board and cable $260
Blitz 52mm mechanical boost gauge and cup $30
R34 plastic eyelids $50 – in sonic silver. Slight bend in one as per picture, does not affect ‘performance’. Affix with double sided tape.
R34 Coupe full set of Nissan moulded mud flaps in Sonic silver - $90
R34GTT Manual ECU sold pending payment
Everything else available, will be throwing them up on ebay
https://www.dropbox.....24.24.jpg?dl=0
R34 Coupe full set of Nissan moulded mud flaps in Sonic silver - $80
TTT
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
