Car travelled only 30,000kms since full rebuild of engine, auto, new paint and upholstery.
Engine rebuilt by Alex Cowie from Cowie Performance Engineering.
Engine has Forged Pistons, mild head wrk with new valve springs retainers etc
Jun Oil Pump Collar with N1 pump
New timing belt kit, and water pump (genuine Nissan)
Greddy type Plenum
555cc JECS Injectors with Spitfire Coil Packs
3 core Alloy Radiator with remote Header Tank
Quality Intercooler
Z32 AFM and new Pod
Turbo Smart Blow off valve plumbed in
Full 3" system
Just retuned by Sean at RFI with very mild tune running only 8psi, capable of 18psi
Walbro in tank fuel pump
Recoed Starter motor and Alternator
Mace Engineering Cold Air Intake Manifold Insulator
Auto Recoed with MV Automatics Stage 2 shift kit
Lowered Kings Coils all round with front and rear camber adjusters
HICAS lock bar fitted
Full Leather Interior
Great paint in AU Ford Naroma Blue Pearl
New Koya - Drift Tek mags 17 x 8 and 17x9's
Tyres are Kumo 235/45/17's and 255/40/17"s
New Windscreen fitted 12 months ago
Rego till August and RWC will be supplied on sale
Denis 0403829350. Located In Ipswich Queensland
$10,000
Edited by barretdenis
https://www.sau.com.au/forums/topic/455888-1994-nissan-skyline-r33/
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
