G'Day,
The short story is that I need Q45 AFM pinouts - ie which pins on the AFM is Gnd, Signal & 12V ??
The long story is :
My PFC has been sitting in my draw for months cause I thought it was busted.
Recently the Microtech that replaced the PFC had some issues and has gone back to Microtech to be fixed.
Meanwhile, I put the PFC back in (no AFM) and sure enough it wouldn't start.
So I tried my standard ECR33 ECU without the AFM connected (as the Microtech didn't use an AFM) - and yep , starts OK, but won't rev past 2500 cause no AFM.
I connect up my Q45 to the standard ECU to get some resolution the ECU - just for a test - and low and behold - it didn't start.
So I try the PFC without and AFM again - no go.
I tried the PFC with the Q45 wired the way I think is right - and no go.
Out of frustration - I put the Y31/VG30DE AFM out of the Gloria in the Skyline, set the PFC to standard AFM )in etc), and hey presto - it works.. O M F G.
So, I either have a stuffed Q45 AFM or I am wiring it wrongly.
Can those Q45 AFM guys with PFC and ECR33 , please advise the pinout of the Q45 AFM ??
Thanks -
Very happy that the PFC works ! :D :D :)
  • Replies 43
Thanks Phil, Yep - that's the way I had it wired -
Are we sure that this is correct ? Cause if so, looks like I am in the market for a new AFM :D
Megs will the Z32 MAF have enough resolution for my setup ?
According to SK's table - Z32 only good for 255ish RWKW. (100rwkw short for me ) :D
Air Flow meters RWKW & Engine BHP
----------- OD ----- RWKW ----- RWKW ------ BHP ------ BHP
No of AFM's ----------- 1 -------- 2 -------- 1 -------- 2
RB26 ------ 65 ------ 149 ------ 299 ------ 271 ------ 474
RB20/25 --- 80 ------ 226 ------ 453 ------ 376 ------ 683
Z32 ------- 80 ------ 255 ------ 511 ------ 415 ------ 763
Q45 ------- 90 ------ 302 ------ 605 ------ 479 ------ 890
Also , can someone explain please the PFC settings for Air Flow ?
You have all the choices of std AFM, Z32 AFM, Q45 AFM and others.
But on my commander, all actual settings are the same for each AFM you choose.
eg
1. 0.64V 100%
2. 1.28V 100%
3. 1.92V 100%
4. 2.56V 100%
5. 3.20V 100%
6. 3.86V 100%
7. 4.48V 100%
8. 5.12V 100%
The are all the same for each AFM type ??
I don't get it.
PS - Midnight Tuners Unite :D
Can anyone tell me - if I get a Z32 AFM then tune the car. Then later if I go a Q45 again, will the car need a complete retune ??
Cheers,
Not "complete" retune, but the readings are quite different between the 80 mm and 90 mm AFM's. It seems to work out about "half" a tune (timewise).
     eg
 1. 0.64V  100%
      2.   1.28V   100%
      3.   1.92V   100%
      4.   2.56V   100%
      5.   3.20V   100%
      6.   3.86V   100%
      7.   4.48V   100%
      8.   5.12V   100%
     I don't get it.
PS - Midnight Tuners Unite :thumbsup:
Sorry for the second post, I forgot to mention this one /|
That's the AFM "correction" table, the actual ramp table (algorithm) for the AFM's is not visible. What you do with the correction table is match an unlisted AFM with one that is listed. You select the closest one in the list to what you are trying to match and then use the correction table to line them up. You do a basic tune of the car with a listed AFM and then fit the unlisted AFM and use the correction table to line up the maps using the map tracer.
Hope that made some sense :)
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
