current mods: rb25det
apexi fc computer/ z32 air flow meter
gt28 turbo (450hp)
600x300x75 cooler
upgraded fuel system
3 inch zorst/twin dump
pod
bov
and im now in the market for some cams, which ones should work best with my setup? i was reading a cams article in speed mag from a few months ago and the application guide says that the 270 intake and 270 exhaust have the best street stars followed by 260 intake and 260 exhaust and these are tomei cams, also will upgrading the cams give my idle a nice lumpy sound?
thanks
https://www.sau.com.au/forums/topic/45626-what-cams-are-best-for-my-setup/
Patience mate, wait for a few of the regulars such as B-Man to see this and they will be able to provide some helpful info. Will assume you are referring to a GTS-T in your post since you didnt mention the car.
Tomei Poncams seem to be a popular choice
what specs are stock rb25det cams.And also what size is recomended to use with the rb25det.Poncams were first on my list of cams to choose from and then i saw others which offered longer duration and more lift but as i understand it to much lift is bad and can cause premature failure of valve stem springs and lead to worse things like a valve in the piston.
what is max lift for tha stock rb25det valvetrain?
also would you suggest using any cam gears when purchaseing a set like the poncams.
does exhaust overlap have a big part in performance with poncams like when using stock cams and adj gears?
heres a list of the tomei range for the rb25det
TOMEI Intake Camshaft
(Camshafts) ¥31,416
Solid LOW Type. 260 degrees duration, 9.15 mm lift.
TOMEI Exhaust Camshaft
(Camshafts) ¥31,416
(Camshafts) ¥31,416
Solid HIGH Type. 260 degrees duration, 10.25 mm lift.
(Camshafts) ¥31,416
(Camshafts) ¥31,416
Solid LOW Type. 270 degrees duration, 9.25 mm lift.
(Camshafts) ¥31,416
(Camshafts) ¥31,416
Solid HIGH Type. 270 degrees duration, 10.25 mm lift.
(Camshafts) ¥31,416
TOMEI Camshaft Kit
(Camshafts) ¥59,136
PONCAM Intake and exhaust camshafts. 256 degree intake and exhaust, 8.50mm lift camshafts. Suitable for NVCS vehicles. Please specify series 1 or 2 R33 GTSt.
Taken from greenline.:)
is it good to mix and match makes.
(Camshafts) ¥31,416
(Camshafts) ¥31,416
(Camshafts) ¥31,416
(Camshafts) ¥31,416
(Camshafts) ¥31,416
(Camshafts) ¥31,416
(Camshafts) ¥31,416
(Camshafts) ¥31,416
TOMEI Camshaft Kit
(Camshafts) ¥59,136
I am extremely interested in this topic and have read many times Sydneykid recommends the Tomei Poncams. I have also been advised, that the Tomei Poncams are only IN256/EX256 with 8.5mm Lift on both.
I'm not sure what sort of power figure you're after but these are not that big an improvement.
The alternative is the HKS Step 1's with IN256/EX264 with 8.8mm and 9.0mm Lift option, which also work with the VVT on the Series 1 and 2 GTS-t.
Can someone please comment on either of theses sets of cams?
Thanks Ken
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
