Hey
ive got a few parts that MUST go!!
Autronic SMC and 500R CDI all set for a VL-comes wit the Autronic EBC,dizzy and leads $2000 will seperate (can supply 6 coils wit the 500R at extra cost)
RB25VCT head with inlet manifold,injectors and fuel rail,and exhaust manifold $500
Custom JD Plenum for RB25-bolts to lower half, comes wit XF TB $500
2xBosch Indy Blue Injectors-BRAND NEW neva used 1600cc $350
VLT Auto-lost 2nd gear, suit rebuild $100
VLT Auto tailshaft $OFFERS$
VLT Cam-excellent condition $80
KKK Turbo-suit rebuild, great for highflow job, T3 flange but needs ext gate $200
S1 Calais front seats in Grey wit headrests-will get them cleaned $100
S1 Calais front n rear seats retrimmed in a blue/purple colour, excellent condition, no rear headrests tho-$300
VLT Inlet Manifold-seems to b ported a bit, no TB n no bolts $80
will add more if i find stuff
make offers!!
it all has to go!!
cheers
Troy
https://www.sau.com.au/forums/topic/45653-parts-parts-n-more-parts/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
