Hah what's with you guys and dinner , my partner was asking me the same questions at 4.30 am this morning [emoji57][emoji57] and he said I can't go to his WRX cruises thingy when I mentioned I'll bring you guys to tag along [emoji13]
i'd be intimidated if i had a subaru and heard Skylines were coming ;)
  • Like 2
haha the Brap intimidates everyone :cheers:
that time i fixed the starter motor and fired it up in the garage, i knew if it wasnt so intimidating your neighbours would have come over and told me to shut the fark up :woot:
Evening all. Busy day was busy just finishing up
Trev, you getting Allstar to retune it? Lachy, how goes the brap?
not sure Corey... I trust him but he just hasnt seemed motivated in the past. im not in a rush to get it done, still a few bugs to sort out. changed plugs today and looks like a small crack in rocker cover breather pipe. need to check tomorrow.
coming for cruise on the water next week when Lachy visits? few Stubbies and 3 red beards in a small spot :3some:
  • Like 1
so the last time the missing purse was spotted it was in a bag full of shopping in the back of the car, so "it has to be at home or someone stole it while i put the trolley back"
"wait, so you think someone opened the back of the car, rummaged through the shopping and found the purse, then shut the door and run off?
so i went down to woolies today and it was behind the counter........ so...... the only logical answer is that someone opened the car, found the purse, run away, then either felt guilty and handed it in, or someone kicked their ass, took the purse and they handed it in :cheers:
either way lucky to have got it back... now only need a new bankcard and she is set
  • Like 1
Shame with the bank card and I don't agreed with PayPass system
still have the bankcard but i cancelled it on monday. new one should be here in a couple days
holy crap i didnt even think about the rewards cards....rookie error :domokun:
Oh god someone is going to claim the new collections Disney Cards ! You're in trouble now [emoji41]
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
