Yep, about to jump on the Jerky wagon!
The Cube is a cool car, basically the same engine and drivetrain as the Micra so parts and stuff are easy to get locally. They look funky, have lots of room and you can buy a bolt on supercharger kit! Perfect city daily.
  • Like 2
Brilliant , that's what I want bigger space inside and perfect for daily use , I have Honda Civic ( Sedan ) as my daily car now but not big enough for what i want to do with it. Thanks Lachy X [emoji509][emoji517][emoji508]
And bonus, it's not a Honda! :woot:
  • Like 2
Don't buy outdoor furnitures from segals [emoji90][emoji35] Cheap furnitures with bad customer service ! Paid for delivery but they refused to bring the goods inside the house , instead leave them all the big boxes outside the house for me to bring it in ? What am I paying the extra $80 for ??????? post-139458-14579294621784_thumb.jpg
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
