I wouldn't say shell is shit. His saying fuel is crap probably meant it wanted to knock easy. Could be high intake temp from no intercooler.
I think 98 is pretty much same but occasionally you get a bad batch
  • Like 1
Inter cooler makes decent improvement. Of fit Water/Meth kit. Standard turbo still? About 12-14psi?
Yeah he said good mid range improvement but it has not arrived yet, he maxed my stock turbo out at 11psi he said it's running out of puff, so I guess that's it for now
$10 for a pair. $18 for 2 pair. Hopefully I can find them as everything got boxed up in the move
I won't stress you with the stickies now , maybe when you settle down with the move then please let me know [emoji5]
Morning boys , is anyone knows about CVT transmission? And is Dualis any good for daily cheap run around ?
I'm sure it's fine as a runaround but I hate them, effectively there are no gears but it can be very efficient
I'm sure it's fine as a runaround but I hate them, effectively there are no gears but it can be very efficient [/quoted
Dave don't like them , he didn't like the sound when it's back off from the accelerator the revs don't drop , you know what I mean ?
It's weird but for some reason apparently it's clever transmission- ha clever to drink up all the fuels [emoji57]
It's weird but for some reason apparently it's clever transmission- ha clever to drink up all the fuels emoji57.png
yeah its just a couple of shafts that just match revs and speed using belts, its good for a runabout i guess
Just now, ElleAli76 said:
It's cheap for daily run , but yea I'm just paranoid with the rev sound -any other suggestion ? How about Nissan pulsar sss
Both my brother and I have had the old 1998 SSS they were cool running the SR20DE was good fun but he converted his to SR20DET GTiR Motor, good fun cars to drive as for the new ones i'm not too sure but probably ok as a daily.
  • Like 1
They are nice transmissions, as long as they have been maintained
  • Like 1
Cool next time I see them I'll let you know. My wife packed them so they could be anywhere ;)
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
