Did you get accomodation for the Friday?
Morning All ,
Oh Martin , I wish I had a personal assistant to do my works , been so busy lately , up at silly o'clock in the morning ( 3.30am) to check All site areas , finish at silly o'clock 8 in the evening and by the time I come home knackered and all closed ( sorry for the whining ) It's going to be long day for me today , I'll try to ring them when I can :( x
  • Like 1
1 minute ago, ElleAli76 said:
Are you going Trev ? It's this Saturday - there is few different events
sorry my bad, i didnt see the date. i assumed it was Friday night before racewars and a cruise around Albany
  • Like 1
Yea there is few events pre-meets before the race wars or the car cruising on Friday next week, I can Join this week pre-meet but , def catch up with youse lot at the dinner party Saturday !
Morning All ,
Oh Martin , I wish I had a personal assistant to do my works , been so busy lately , up at silly o'clock in the morning ( 3.30am) to check All site areas , finish at silly o'clock 8 in the evening and by the time I come home knackered and all closed ( sorry for the whining ) It's going to be long day for me today , I'll try to ring them when I can [emoji20] x
You should get a PA then [emoji6]
  • Like 1
oh your going to the dinner party?
i thought you were baby sitting my kids :)
  • Like 1
  • Like 1
Now working the Sunday morning shift at RaceWars, if anyone wants to join me at the 6 Degrees to see the NBL grand final game 3 they're more than welcome.
http://sixdegreeshotelmotel.com.au/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
