I want hot chocolates drink [emoji24][emoji24][emoji24] got home late at 12, was up again this morning for site visit , then to the gym , stuck in traffic for good 1 hour [emoji24][emoji24][emoji24] at John now and meeting soon :( help
I want hot chocolates drink [emoji24][emoji24][emoji24] got home late at 12, was up again this morning for site visit , then to the gym , stuck in traffic for good 1 hour [emoji24][emoji24][emoji24] at John now and meeting soon [emoji20] help
That calls for a quad espresso I reckon Elle!!
  • Like 1
Redbull gives you wings??
I left here on a Saturday morning, got to Gold Coast Monday. Was fidgety and couldn't sleep til Tuesday. Cleaned the car the following day and found 27 red bull cans and bottles.
I'm sure I nearly broke a rib my heart was beating so hard
  • Like 2
Thats commitment!!!
If any of you guise know how to read, "the Martian" by Neil weir is a great book. I finished it today and it was very hard to put down. Its in my top 3 books ever. Matt Damon was in the movie.
  • Like 1
No sorry I can't read [emoji6]
  • Like 1
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
