I want hot chocolates drink [emoji24][emoji24][emoji24] got home late at 12, was up again this morning for site visit , then to the gym , stuck in traffic for good 1 hour [emoji24][emoji24][emoji24] at John now and meeting soon :( help
I want hot chocolates drink [emoji24][emoji24][emoji24] got home late at 12, was up again this morning for site visit , then to the gym , stuck in traffic for good 1 hour [emoji24][emoji24][emoji24] at John now and meeting soon [emoji20] help
That calls for a quad espresso I reckon Elle!!
  • Like 1
Redbull gives you wings??
I left here on a Saturday morning, got to Gold Coast Monday. Was fidgety and couldn't sleep til Tuesday. Cleaned the car the following day and found 27 red bull cans and bottles.
I'm sure I nearly broke a rib my heart was beating so hard
  • Like 2
Thats commitment!!!
If any of you guise know how to read, "the Martian" by Neil weir is a great book. I finished it today and it was very hard to put down. Its in my top 3 books ever. Matt Damon was in the movie.
  • Like 1
No sorry I can't read [emoji6]
  • Like 1
