What's everyone up to besides RW and dinner in Albany?
I'm hoping to climb bluff knoll or porongurups, the gap and maybe old whale station or museum etc
Weather dependant but keen for the bluff done everything else and don't imagine it has changed in 10 years [emoji6]
  • Like 1
Yep just did the mountains today playing with the cannons got em moving up n down tomorrow ill go to the museums. Had a super good dinner at Hybla seafood delicious!!!!
Cool ! Thanks for Sharing ,
Love seafoods [emoji39][emoji39]
Morning All !
  • Like 2
All ready to go Trev ?
Naa not really. I turned the fridge on in the van last night. Gotta load it up yet.
Owen wants to go to school for the morning so we will get him at 12 and get going
  • Like 2
Good for you Owen :) so you're not with the convoy or you're catching up with them
Somewhere ?
Good for you Owen [emoji4] so you're not with the convoy or you're catching up with them
Somewhere ?
We will go back roads that I know to save time and avoid traffic. We will be there about 5pm
  • Like 1
Is that quicker and away from traffic ? Dave's concern about the traffic ,cause its public holiday
