we sure are elsie. hopefully get down there at 10am pending breakfast and cawfee breaks on the way down. Have downloaded a movie for wifey to keep her quiet
Awesome ! Finally to get meet you and your family :) I'll see you tomorrow night at the dinner party Corey !
  • Like 1
One of the cars must be staying at my caravan park. Has straight through pipes and sounds lumpy for a small engine. He left 3 minutes ago and I can still hear it in the distance revving its ass off
  • Like 2
Corey is going home before dinner. His wifey has to work Sunday
Work on Sunday :( what a shame , oh well are you there yet Trev ? Camp out ? Take
Some pictures too please :) can't wait to see you all tomorrow [emoji7]
Work on Sunday [emoji20] what a shame , oh well are you there yet Trev ? Camp out ? Take
Some pictures too please [emoji4] can't wait to see you all tomorrow [emoji7]
Yeah we got here yesterday about 6pm. We are going sightseeing til lunchtime then head to racewars
  • Like 1
Morning Dean , Paul & Martin has mentioned a lot yesterday , sight seeing bla Bla bla Bla - The Gap , blah blah blah - [emoji23] and I can't recall , have to scroll up and read again when I get there [emoji23]
  • Like 1
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
