8-10 on what?
New stereo was about 1100
New Michelin PS3 245/40ZR18 all round
Wheel alignment, parts
12/8/16
Nistune, tune and alarm system install at C-red
19/8/16
New Spitfire coils and power tune at C-red
New front discs ordered DBA T3
Braided brake lines
Tein coilovers
New replacement coil harness
Cooling pro stealth intercooler and piping
124000 - 30/7/16
Coolant flush and replace with Red
Oil and Filter flush and replace
Transmission oil flush and replace (Partial sump only)
And a whole bunch of little shit
  • Like 1
Not sure mate just having a look at what's out there, not keen on a certain 400hp with stock turbo r33
Considering checking out modifications for the 34 tbh east bear kit and a paint job/body work and some nice wheels then up to 300hp work from C-Red & drop a manual in it, just need to weigh it all up
Manual conversion 3k maybe lil more with better clutch
New computer 700 (nistune) - 3000 (haltech)
Injectors 500 -1000
So many turbos to choose from but go hypergear ATR43SS (its what im going to go and trev has) 1600 approx inc lines plus you can ad extras (bushings vs bearings)
Exhaust 500 -3000
Upgrade to more acurate guages 1000
@t_revz anything else you reckon?
Oh if u do go haltech you will want the dash to go with it.
Injectors 500 -1000
Exhaust 500 -3000
he has nistune already
injectors $1000
SS2 turbo is gooooood
exhaust $1000 for 3 inch straight though with 1 muffler and jjr bellmouth dump
fuel pump upgrade
and Nos....2 of the big ones!!!
your welcome to try mine to see what an SS2 feels llike before you buy
just watch out for Kerbs
  • Like 3
Just now, z00key said:
Yours bushings or bearings?
ball bearing. SS series 1,1.5,1.8,2 and 3 were all ball bearing.
atr43 series was bush bearing.
not sure about the new SAT series. i havent kept track of that topic for a bit
used to be around 900 for atr and 1600 for SS. about 400-500rpm difference in spool
  • Like 1
It has a 3" exhaust turbo back already but it's a Mank one from a dodgey shop so would replace when a new turbo is bolted up.
Needs new injectors, fuel pump, afm, turbo to make 300 ish
Spoke to Mark about E85 he said don't bother
3 minutes ago, shoey85 said:
I
yeah you wont need e85 for 300
i did 266 with hiflow turbo, intercooler and powerfc with a bit more boost. maxing out injectors and AFM
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
