the army still staying at your place?
SAUWA safari trip??
Actually that's not a bad Idea ! Hop on bus tour for SAUWA members ! Hahahahahaha truck's leaving next week :) ship [emoji568] To Dubai [emoji1256]
  • Like 1
Hahahahahahahaha ! Awwwwww poor Skyline [emoji23][emoji23][emoji23]
It's far from a laughing matter for me, it may be an average car but I'm gutted.
Not sure how ppl get over it when their car is stolen and recovered
Our lawyer got his S5 stolen and returned with a load of drug paraphernalia so he didn't accept it and then got a Volvo S60 instead
So I guess that's how you do it
1 minute ago, Manne said:
theres no discounts on consoles, sorry.
That does not tell me how much it costs and where to get it from.
Or are you saying I should just go to my local EB/K-Mart/JB Hi-Fi?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
