Hahahahahahahaha Nah Nah Cant tell Elle !
Oh How I wish I can go to Japan and visit the Nismo factory ☹️
Man I seen it in a magazine today. Close as I'll get for a while. Carbon fibre toilets.
  • Like 1
FB_IMG_1491644722599.jpeg.d066c423c299ac43538365b393774bbf.jpegFB_IMG_1491644718996.jpeg.34a1f25dd627c79432a167625c178e5b.jpeg
Went out for a drive today with the girlfriend to mundering weir and around.
Was good fun for a few hours with out the kids.
Beautiful pictures. I often get up at around 5am and head out to canning mills road and to the weir on Sunday morning. Have to take it easy because the boy gets up early and always wants to come with me. Always come back to a coffee and toasted sandwich at hungry jacks in Armadale or kelmscott. Would be a good cruise for early risers. Police changing shifts, passing Ellie on the uphill walk in the park bike ride. Let's be honest it's the only time the gtst will pass her!
  • Like 2
Rack of lamb, marinated chicken breast, baked potato, sweet potato, onion, jap pumpkin. Fresh cauliflower, broccoli. Beans and corn. Red wine and garlic gravy. Show us your dad!
evening all. all jobs around the house sorted before we go away.
just gotta pack clothes and a quick trip to the shops in the morning. cya tomorrow [mention=135083]z00key[/mention]
May the Schwartz be with you. Spaceballs.
A zero is prob missing off it but incase ??????
Please view this ad:
Nissan Skyline R34 GT-R V-Spec II - Manual - 71,688kms,
http://www.gumtree.com.au/s-ad/yokine/miscellaneous-goods/nissan-skyline-r34-gt-r-v-spec-ii-manual-71-688kms/1144570492?utm_source=com.google.android.apps.docs&utm_medium=social&utm_campaign=socialbuttonsVIP&utm_content=app_android
Price: $12,000 Negotiable
Download the application from the Google Play Store.
http://goo.gl/7NzhP
  • Like 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
