Looks sweet nice tip!
Most of the hot dogs you see always run up at a big angle. Nice to see a oval tucked up into the space where it's supposed to go. The rear oval is always a good option because the more acoustic packing the deeper the exhaust note. Well done looks great!
The Lukey mufflers have always been a high quality product.
Hows Japan taking you?
So far so good. Going away with friends for a few days early next week which should be good. No idea where to yet, but we've organised a 10seater mini-bus and see what looks good in the next 24-48 hours or so. Maybe head to Oita.
  • Like 3
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
