I have to go to the pool at least 3 times a week for the back. I normally do excersize and stretches in the hot hydro pool then go to the 25m pool for walking and swimming laps. I've got dodgy knees too and if I walk too much in the pool they ache real bad but it's only Austio arthritis. I was in and out of physiotherapy for years and just pissed it all off did a load of research and found a balance that works good for me. What is the main problem with the knees?
A few of my mates I played footy with had Osgood/slaters and it finished them. After over 200 games of footy I wish I'd never played but I loved it alot. Football is my family's religion! But I've lost interest over the last few years. Not as hardcore as t-revs with his West coast Eagles engine bay!
Yeah not bad. How was the drive home car still good and did ya hav3le a grin going home thinking I got a 12 sec car
Hey Dean I found a awesomeness little R35 on Gumtree for the boy. Would post the link if I knew how. Have you got any of the r/c's up and running?
  • Like 1
1 hour ago, Beyond Blue R33 said:
DSC_0348.JPGDSC_0347.JPGthe earlier time was the faster. Dropped it to 30 psi all round today. Do you think the duramax 75-90 is the right oil for the diff? It was juddering bad when I changed it then came good with the l.s.d. Paste and figure of 8's? The tein basics have only height adjustment and the ride is hard as since I lifted I't?
Track temp definatly didnt help, colder it gets the less sticky it becomes and less traction u get. Same principle when its too hot.
Diff oil sounds about right, was the old oil burnt? Id day that the shock from spinning the tyres to it gripping proberly caused it to tighten up through heat. New oil and a some maneuvering always helps.
Ur shocks are gonna have more travel due to increased hight, more fluid to move bk and forth within its stroke which will make it feel harder
  • Like 1
Hmm makes sense, that's what I was thinking too much extension and not enough compression in the shocks which would coincide with the longer travel and higher spring rate. When you gradually build up the boost and launch it sweet on the street is the only time you notice it. The old diff oil was clean as. I was also thinking due to getting cold between runs that it was at its minimum viscosity but the thinner the oil it should make its way into clutch packs better?
I watched footy in high school and early twenties. Now I despise it. I'd rather watch netball or lawn bowls
  • Like 2
i watched WM on youtube. there is 26 x 22minute episodes plus there is a movie
i enjoyed the series more than i expected. initial D was better but its still very good. the movie isnt bad from memory either
  • Like 1
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
