Out of interest where would you put the auto flex? Assuming you're doing it yourself not looking at pics or posts? Before or after the cat? Would be keen to see all the pics of your build? Must be a insane machine? A veritable titan?
I have photos that show all of the exhaust except the front pipe where the flex joint was.
1 hour ago, TiTAN said:
She wasn't pretty. But she got the job done.
4" dump, 3.5" front with flex pipe, 3.5" cat with 5" body, 3.5" to the middle muffler, 3.75" to the rear muffler and a 4" tip.
25/30 with a gt3582, 394kw @ 26 psi and 90db @ 3500.
This is the exact setup im going for.... ? atleast i know what to expect ?
2 minutes ago, TiTAN said:
Expect that the 38mm height difference in the block is far more annoying than you think it's going to be.
I have a grinder, hammer, welder and a soldering iron. We can make 38mm work lol
Stirred in natural yoghurt before serving:-) yum
Jack wanted to make a Korma chicken curry today? I'll show you how mate marinate the chicken. Set it aside. Get the oil hot close to bubbling then ad the spices stir and only just spoon in a few pieces! All the chicken dropped out the bowl into the piping hot oil an whalla!DSC_0149.JPGDSC_0148.JPG
Jack wanted to make a Korma chicken curry today? I'll show you how mate marinate the chicken. Set it aside. Get the oil hot close to bubbling then ad the spices stir and only just spoon in a few pieces! All the chicken dropped out the bowl into the piping hot oil an whalla!DSC_0149.JPG.1e949b087f3dda053e6ca7f4cdb3b4f0.JPGDSC_0148.JPG.68d26367b6202780e3b0c0dde2c346c1.JPG
This is my hand, splashed the piping hot oil onto it. Chicken Korma with blistering skin! Yum!
Frankensteins monster, bolt of lightning to fire up that nasty s.o.b.!
Exhaust won't fit, intercooler piping won't fit, clearance to the clutch master cylinder is quite tight, cam belt covers need to be modded.
Wiring isnt an issue from memory, it's just anything that used to bolt onto the head or between the head and block are now 38mm too low/short/out of place.
Sounds like a giant ill fitting jigsaw. Im sure il gwt it worked out with a lot of swearing and cursing
OUCH
Blistered up yet?
OUCH
Blistered up yet?
Amazingly looks pretty good today. Did 1 hour of cold water on off till the heat disappeared. Wrapped in sterile cloth and glad wrap. Nurse said just put antiseptic on for 5 minutes then pat clean keep re laying dressing.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
