The only thing hard about skylines is the back ache u get from bending over them all the time. Low coupe fails lol
Yep back is dying. Spent all day tig welding double bellows. Came in with the wrong pressure rating flanges from Malaysia. They are paying us to fix them. Had to cut off all the 16mm flanges and fit 38mm thick flanges (5/8" to 1 1/2") Pulse weld all the triple ply ends back together (0.4mm thick) then fit the new flanges. Had to be welded to a weld procedure to Australian standards. 16 hours solid tig so far. Been fluffing around with the car at night also. Totally warranted a 4 pack of bourbon tonight. I am old.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
