Sup guys my mate Avacardo is gosting a cruise (quite a big long one about 2hrs) for anyone interested
I'm in for it Dean if nothing crops up! How's the recovery going? Not trying to get me arrested again? [emoji23] Seen a beast exactly like your 34 parked in Bennett Springs today but a coupe. Same colour and rims. Put some pics of your car in my screen saver at work. The boys loved it! She's a tidy machiene. Hope all is well with the wife and baby!
  • Like 1
Car stereo will never compete. 901's, gale gs401a, dual mordant short centres, 301 rears. 2x Yamaha 1x marantz and a 140wpc nad from the early 80s either watt meters.
Just a thought! Might have fitted the Nissan:-o DSC_0265.JPG.84668072bdd034387456de3d5f9f2ac4.JPGDSC_0268.JPG.6418231729271f783d2fbd5962b365e0.JPG
901's 250wpc at 8ohms, so beautifully efficient chained to the rafters. Running gale g's 401a's as subs. Audiophile at home. Got 2 Yamaha 1 marantz and a 140wpc nad with watt meters from the early 80's.
Anyone ready any of the hypergeat turbo thread? Currently up to page 539 since friday night, my head hurts
If you want the best balance, smaller highflow good for 250ish on 98 then run it on e85 for high 200s and minimal lag for everyday Street use. Enough go to get you solidly moving but without the 3500+ rpm boost threshold.
I'm not sold on the benefits of the 300kw+ ones vs off the shelf big buck engineering jobs. Surely a gtx3071/3076 will perform better for transient and response even if they make the same peak power.
  • Like 1
Yep. I normally go to Whiteman park and Malaga every year. 3 mins from home both directions. Followed every stage a few years back.
Went to the zig zag stage ages ago. Got all set up over the 3rd hairpin. Set up my camp chair got out the esky with some beers and chicken sandwiches. Looked down after about 15 mins to see I'd disturbed some Kalamunda locals being massive bull ants. All over the chair esky shoes and sandwiches were totally null in void with ants. Had to do a massive f##k dance shake everything down and spent the rest of the day with full paranoia and little itches that might have been more ants in the pants! Leeusseer:-)
  • Like 1
I'm laggy up to 3500 with the SS2 but it doesn't affect it too much with the 4:1.1 and 5 speed if your in the right gear at the right time. With more power I'd definitely be looking at a lower ratio. So 115-120kph isn't 3000rpm cruising. Having said that the exhaust planes out pretty quiet for a 3" straight through and now we can give it "justice." On the stereo. Even 3-4 at 18psi didn't lag at the drags and it kept pulling hard at about 6750rpm over the line at 177kmph. Have shifted 5 at about 195kmph and it is always over 3500rpm in the rev range when you pull the next gear. With a kizza motor and tuning I couldn't see it being a problem?
Yep. Agreed. How did it run after the clean?
Same same. It starts better on cool mornings but only marginally. Perhaps a touch pokier taking off but maybe just my imagination. Fuel economy appears unchanged. I'll know by Friday when I refuel
  • Like 1
There isnt a whole lot of info on rb30dets in my desired relms of use. Most rb30dets area drag monsters...
  • Like 1
Im thinking atr43ss4/5. Ss2 mite chocke my rb30
Right rb30.
3076/3071 minimum. Anything that uses a stock rear housing isn't going to flow enough exhaust and will choke hard up top.
Gtx3071 with a 0.82 hot side should have full mumbo at 2500 but with 300kw potential. All the meaty ass midrange without making so much power that it's unreliable and laggy, if you want power more progressively use a 1.06 hot side.
  • Like 1
4 minutes ago, TiTAN said:
Right rb30.
Gtx3582r with an 50mm external gate is what i was also thinking. Either way i think external gates gonna be better
Ss2 would be punchy on a 3.0l. What's your top end power goal?
High flows have been tried on an rb30 years ago. It was a cheap build basically stock Na bottom end with the 25 head and it came on like a light switch but come 5000 it hit a wall, by 5500 it had dropped about 100kw from memory.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
