Gazebo. Or as I like to call it the white elephant. Wife had too have it. Brand new, never been used, no joy riders low ballers or time wasters. DSC_0315.JPG.5f92282c373ab30fb15b9cd82cbc2e93.JPGDSC_0317.JPG.72825973a1ab5f50dd25fac81a0bf604.JPGDSC_0316.JPG.be990c31d3136a28471933744a36c515.JPGchews more oil than a ls1:-o
Dad reconds if there is a earthquake or cyclone head out to the gazebo or patio. Totally over engineered.
  • Like 1
The cubby I built for the kids at our last house could hold a herd of elephants [emoji208]
  • Like 3
Will how convenient. Wondered if i may ask a favour if anyone knows and could help. My front lounge is open living and we would like to put doors on the 2 entries/exits anyone know how i would go about doing this? Would it be a hard jod to do or be able 2 give me a hand to do it?
A full herd of white elephant ridiculousness, the sheer irony is that the gazebo replaced the kids old cubby house. 90x90 timbers fully concreted and solid braced floor. Pine paneled door, windows, eaves out on to a small patio. Stud frame and full weather board inside and out. Full corrugated green roof to match the house. I slept in it a few times while drinking beers and listening to the radio in raging bad weather to sheerly justify the amount of work and expenses. Kids never used it! Fully funny to hear a similar experience. I lost my s##t. Again!
20170901_181439.thumb.jpg.784d04faeeb0f9bfbc71bd8c4b540738.jpg20170901_181431.thumb.jpg.86c5e61a41cf45adf8fa6509fb4298cf.jpg
The doors you get at bunnings/masters etc. Are generally only a generic size. You would need to put a architrave in (metal or wood) the metal architraves generally have the hinges built into the frame work. The first pic looks like a bigger width than normal. The second pic looks pretty standard. From memory doors are normally. 715mm small 815mm large. Could be 720, 820. Then once the architrave is in you just plane them down to suit because the doors have thicker wood on the outside the internal frame. You also have to fit the door handles and cut out the locking mechanism into the architrave.
I prefer working with metals, fuxk it up and u can weld a bit on. Cant do that with wood lol
  • Like 2
These 2 doorways am wanting to put doors on
Buying generic pre hung doors is easiest. As you don't have to work out the hinges etc. You can probably get them with hardware pre installed too at a bit of an extra cost.
put the door and frame into the opening and then make a bit of frame work around them to join them solidly with the edges of the opening/roof/floor. Leave yourself a small margin around the door for spacers to align the door. cover the frame work in plaster board, go for gold with the joint compound and spread it reasonably wide (~10cm wide over the join and don't be afraid to do a bit of sanding, then go for the finer top coat at ~20cm wide and sand again, it makes it harder to see there is a bump. Going too narrow makes the bump more visually obvious).
you may need to take some plaster board off around the edges of the existing openings to remove any plastic/metal reinforcement pieces on the corners for a better finish.
The most important thing is to take your time getting the door in the correct spot before you screw it in properly (square/straight) so the door stays where you open it to instead of naturally wanting to swing open/closed.
If you want pocket doors then that's a whole world of hurt to retrofit, just pay a pro to do those.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
