Gazebo. Or as I like to call it the white elephant. Wife had too have it. Brand new, never been used, no joy riders low ballers or time wasters. DSC_0315.JPG.5f92282c373ab30fb15b9cd82cbc2e93.JPGDSC_0317.JPG.72825973a1ab5f50dd25fac81a0bf604.JPGDSC_0316.JPG.be990c31d3136a28471933744a36c515.JPGchews more oil than a ls1:-o
Dad reconds if there is a earthquake or cyclone head out to the gazebo or patio. Totally over engineered.
  • Like 1
The cubby I built for the kids at our last house could hold a herd of elephants [emoji208]
  • Like 3
Will how convenient. Wondered if i may ask a favour if anyone knows and could help. My front lounge is open living and we would like to put doors on the 2 entries/exits anyone know how i would go about doing this? Would it be a hard jod to do or be able 2 give me a hand to do it?
A full herd of white elephant ridiculousness, the sheer irony is that the gazebo replaced the kids old cubby house. 90x90 timbers fully concreted and solid braced floor. Pine paneled door, windows, eaves out on to a small patio. Stud frame and full weather board inside and out. Full corrugated green roof to match the house. I slept in it a few times while drinking beers and listening to the radio in raging bad weather to sheerly justify the amount of work and expenses. Kids never used it! Fully funny to hear a similar experience. I lost my s##t. Again!
20170901_181439.thumb.jpg.784d04faeeb0f9bfbc71bd8c4b540738.jpg20170901_181431.thumb.jpg.86c5e61a41cf45adf8fa6509fb4298cf.jpg
The doors you get at bunnings/masters etc. Are generally only a generic size. You would need to put a architrave in (metal or wood) the metal architraves generally have the hinges built into the frame work. The first pic looks like a bigger width than normal. The second pic looks pretty standard. From memory doors are normally. 715mm small 815mm large. Could be 720, 820. Then once the architrave is in you just plane them down to suit because the doors have thicker wood on the outside the internal frame. You also have to fit the door handles and cut out the locking mechanism into the architrave.
I prefer working with metals, fuxk it up and u can weld a bit on. Cant do that with wood lol
  • Like 2
These 2 doorways am wanting to put doors on
Buying generic pre hung doors is easiest. As you don't have to work out the hinges etc. You can probably get them with hardware pre installed too at a bit of an extra cost.
put the door and frame into the opening and then make a bit of frame work around them to join them solidly with the edges of the opening/roof/floor. Leave yourself a small margin around the door for spacers to align the door. cover the frame work in plaster board, go for gold with the joint compound and spread it reasonably wide (~10cm wide over the join and don't be afraid to do a bit of sanding, then go for the finer top coat at ~20cm wide and sand again, it makes it harder to see there is a bump. Going too narrow makes the bump more visually obvious).
you may need to take some plaster board off around the edges of the existing openings to remove any plastic/metal reinforcement pieces on the corners for a better finish.
The most important thing is to take your time getting the door in the correct spot before you screw it in properly (square/straight) so the door stays where you open it to instead of naturally wanting to swing open/closed.
If you want pocket doors then that's a whole world of hurt to retrofit, just pay a pro to do those.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
