Looks like you had a hell of a night rooster!
Seems to me they lived their life with a candle in the ring. Never knowing who to cling to when the pain set in. It's a Elton john aids benefit cult.
  • Like 3
Good mate, we will get the car next week, just some finishing touches to be completed, Nismo lights arrived today so i dropped them off and get a few more pics
IMG_0058.HEICIMG_0054.HEICIMG_0061.HEICIMG_0060.HEIC
Looks About right [emoji23]
Phil is too Busy to have a Chat with me today [emoji849]I Cant do weekend either As ill be working from 8am-11 Night Both Saturday sunday !
Call him Monday, can’t wait to see what you get!
  • Like 1
2 hrs of kayaking. First 90 minutes was great then the wind picked up and was a battle to even move forward
Push on or turn back and ride the wind. I seen a picture on here detailing a gas fired kayak ignition system. Either option would be painful. Lucky you have a wideband installed in the exhaust.
  • Like 1
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
