Now with the exhaust is different , I didn’t go with Chinese brand like what I’ve got now and FYI I didn’t have that install it was from previous owner , it’s still loud but I don’t like it as it didn’t sit very well.
With genuine Nissan’s exhaust yea it’s good but it’s not loud enough like how I want it.
So I go with HKS , it’s loud enough than the current.
Now questions - do I need to re-tuned the car with the new exhaust ? What about the horse Power , would it impact ?
If it's a cat-back system it won't affect the stock ecu tune. It will have sensors before and after the cat converters so it should just flow more at high revs and sound awesomeness at idle. If the original Nissan system had reactive mufflers at the rear and not straight through you might loose a bit of bottom end torque but gain more power at higher r.p.m. A proven hks product will just bolt on and be mint for what you want (moar top end and moar noisy) unless you've changed the tube size.
Sounds like the bushes are dead!
I noticed when we went to mighty car mods you had a massive clicking at the front end like cvs on full lock when parking. Won't be anything to do with clunking though.
  • Like 1
I would think the upper control arm bushes could be pressed out and replaced from experience. But I've never owned a highly technological beast like your bad boy. On the cars I've owned it would be just do both sides with nolathane's? Red bushes are stiffer and faster.
  • Like 1
With what you've been paying galvsport they should be providing you with the proper information and pricing?
  • Like 1
They did ! And what Nissan’s want $2300 one month eta !
And Galvsport wants $1700 :) but not sure with the eta , I think he prob order them from just jap
You think alike with dave , he said that before but guess the qualified mechanics should knows better lol no offense! [emoji23]
  • Like 1
Josh said the same thing about having the cvs in full lock - and it’s not a safety concerns.
But the sounds bugging me ! Can you help ?
Get tbe bushes and il do it for a carton lol
  • Like 1
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
