Mostly bonnet and right B pillar then there’s other imperfections in other panels, am I asking for too much here?
When mine was painted I couldn’t find any imperfections
Something is very wrong with yours
  • Like 1
I'd be taking it back to the painter,  you payed good money to have the car painted properly. Maybe take the car to other paint shops and ask their opinion on what the cause would be (in their experience) before you go back, so that you have an understanding.
I wouldn't accept anything but perfection, if that's what you were paying for.
Including the insurance payment we would have spent $13,500 on the paint and repairs
  • Like 1
Nope, should be perfect! Specialy if they paint exotics sports cars....
2 hours ago, t_revz said:
Haven’t.
Yeh but not sure if it’s from when running which I think is unlikely or once shut down
Id run a leak down and comp test once warm just to be sure theres nout else wrong.
4 minutes ago, t_revz said:
I only started testing the oil after building the engine and it’s always had dilution.
Must be an injector then, sticking on shut down. Do u get alot of popping and banging on over run?
as unbelievable as it may sound....
i might drive the skyline this week... [emoji4] i cant even remember which month it last moved but the dust suggests 4 months or so
Perfect dimensional outline on the floor:-)
  • Like 1
Here is our paint issue it’s hard to see but it looks like it was sanded with 80 grit before spraying
IMG_0110.thumb.jpg.8fb24821e37c1b7b1d9064de554df5e3.jpgIMG_0108.thumb.jpg.95ee091895cd070feca9172d662919a6.jpgIMG_0107.thumb.jpg.c600c082c629f80c4e14ca6b718e0c63.jpg
Yeah I reckon youre pretty right on that Martin. I used to make polished aluminium bull bars. 24grit to take off the top of the weld. Blend the corners with 120 on 7 1/4" sander. Then to 180 and 360 with orbitals before double polishing. One slip with the heavy grit or a dig (sander not flat) and it was all over. Deep looking swirl mark scratch. If you tried to polished them out with the hard buff wheel it would scallop out the Ali and you'd have a pocket that showed up like dog balls in the sun.
I asked Larry Kosilla what he thinks it is and this is what he said
Quote
"Hey bud
It looks like the wetsanding was not done properly :(
Or the paint could have stretched when painting...who knows. But it needs to be fixed by the painter. Yikes!"
Larry is one of, if not the BEST Detailers in the world and is who I turn to whenever I have a query about detailing cars.
https://www.instagram.com/ammonyc/?hl=en
  • Like 2
Both of my brothers worked at a paint shop and have both said stretching but where there are cross hashes they reckon poor sanding, who knows?? Phil’s seen it and agrees it needs attention probably December or in the new year tbh
  • Like 1
40 minutes ago, R33kizza said:
Was thinking excessive fule being burnt in the exhaust manifold, turbo or downpipe
nope. and i have a wideband and its been leaned out at cruise which the last 1000kms was constantly at
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
