fkn frustrated with the car atm, paints gone to shit, alarm is playing silly buggers, and today the indicator decided its not going to cancel any more FFS!!!
That was me a year ago. Me and Dave test drove it. Pulled hard at 7000. Dave broke the ton in a 60zone. Breaked solid, handled awesomeness? Stalling on the way home after purchase. misfire 2 days later, front brake discs and pads died, steering stopped centering, holes in exhaust, radiator shit it's self, immobiliser shut ignition down. Rear seats had no bolts, doors wouldn't shut. Intercooler pipes leaked, tyres had chunks and holes from ridiculous camber. new coil packs, plugs. Oil change. Rack rod ends, castor arm bushes. Full exhaust, new front slotted rotors and pads, lifted ride height, rewired immobiliser and spaghetti under dash. new cat x 2, blew the 100cell ceramic to bits and melted it. New master and slave cylinder sleeved, clutch fork came off pivot ball, new gearbox oil. New diff oil, diff chattering bad, Ford lsd paste fixed it. Stereo crackling and not working, full custom install, new tyres. And foot settings. Air con compressor clutch sized, new compressor. Cleaned Iacv replaced solenoid. A/c whirring noise in dash now and rattling. Revs dropping to 500rpm when a/c fan cuts in. Load on alternator. Rattle near turbo under full load and running rich. Easy outed and replaced manifold and turbo bolts. Blatantly refuse to fix anything else till the turbo fins enter the exhaust. 1 full year of skyline ownership. ;-)
  • Like 1
Its all part of the fun of owning a skyline....
  • Like 1
I can hold my cool for 3 or 4 mins then it all goes in the bin lol
That's why the bouncers took martin's I/d, imagine the big bald headed unit cutting loose chocking the f**k out of a tiny Japanese steering column, scary>:)
  • Like 3
On 12/18/2017 at 7:24 PM, shoey85 said:
R34 the Manual is so good, think my 4th synchro may be on its way out.
215 as an auto then 245 as a manual he said he did see 250 on one run but couldn’t find it, also he didn’t do a full solid power run for show.
Next time or any dyno days coming up would be keen for a run!
Now I want to go for a cruise in the hills!!
Nice!
My old auto on a hot day made ~190rwhp (not that you can compare 2 different dynos), still nice results!
If you wanna go for a cruise we should do it while I have this (it's not turbo though)
  • Like 2
Nice!
Naice!! And yes let’s do it, when you free?
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
