1 hour ago, Beyond Blue R33 said:
Check it out. 6 from 12 studs snapped under ring spanner back and forth careful arm pressure.centre popped and easy outed all fully drilled, tapped and ready for new genuine nissan studs washers and nuts. The manifold was so warped it was ridiculous. It's in being Re-faced now. Butter bolt studs and rattled up I reckon. Madness.
Sounds about right, proverly been off befor and supercheap studs fitted! Check this out, complete clutch basket failure on 1 of our drag bikes (i now crew on 2 cars and 2 bikes lol) iv never seen it ever.... all the fingers are gone lol
  • Like 1
Looks like it was machiened on a lathe. Haha. Mental
I heated mine up white once when it had a problem and it was distorted about 10mm across faces
Had to get another one
  • Like 1
Paid with more work and high expectations?
  • Like 1
Labour of love, engine rebuild and some light fabrication to fit a turbo to it [emoji48] 8.50s here we come
You're a animal. [emoji882] top of the line German to drag 2 wheel 4 wheel jap and everything in-between. Big Jobs. I've been stuck inside the belly of the beast. Madness. Slowly but slowly. Pulled the last poxy bolt with 3x extensions and a uni joint on the rattle gun that was hidden away drilled and tapped into a I beam across the chassis rail. Ffs.DSC_0187_2(1).JPGDSC_0177_3(1).JPGDSC_0186_2.JPGDSC_0183_4(1).JPGDSC_0194_4.JPGDSC_0196_3.JPG
On 04/03/2018 at 8:49 PM, Beyond Blue R33 said:
You're a animal. emoji882.png top of the line German to drag 2 wheel 4 wheel jap and everything in-between. Big Jobs. I've been stuck inside the belly of the beast. Madness. Slowly but slowly. Pulled the last poxy bolt with 3x extensions and a uni joint on the rattle gun that was hidden away drilled and tapped into a I beam across the chassis rail. Ffs.DSC_0187_2(1).JPGDSC_0177_3(1).JPGDSC_0186_2.JPGDSC_0183_4(1).JPGDSC_0194_4.JPGDSC_0196_3.JPG
f**k that for a laugh, looks like a right twat of a job lol
  • Like 2
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
