I have a Power FC to suit a ER34 R34 GT-T for sale. Item is still in the original box with all English Instructions, Serial Codes, etc. It comes with the Power FC Command hand control, the ECU unit which is Plug and Play. Replaces your original ECU. When it was fitted in my car, it was tuned to suit a FMIC, Turbo-back Exhaust (standard hi-flowed turbo though), Pod filter and abit more boost.
I am seeking around $900 or the nearest offer.
I am also selling the Apexi AVCR also still in the box. This is the updated black screen, white LCD display version. I am seeking around $600 or nearest offer.
Lastly, there is a pair of carbonfibre mirror covers for sale. It's attached via 3M double sided tape which I have not used them to date. So they are still new. I'll consider any offers above $30.
Text me on 0434970678 or if you prefer, PM me but I don't login everyday. Note if you are interstate, I will post you the item but you will be paying for the Australian Post cost and I must receive CLEAR payment before sending the items. Happy for you to pay via PayPal if this helps by dealing through eBay.
  • Like 1
Power FC sold. AVCR still available.
Also available is my standard ER34 intake Airbox with the original filter element and an after market intake box. Seeking $30 or nearest offer.
Also has a big bag of replacement Globes for the dash and centre console. Bought the series 2 version white/blue lights from Nissan previously. Dealer is such a knob that I only wanted 1 globe but ended up having to buy a whole bag with 20 globes inside. Seeking $30.00 or nearest offer for everything I have at hand (prob 20+ globes).
Finally, have some exhaust heat retaining cloth wrap. Seeking $10.00
Happy to post but you will pay Australian Postage (Registered) cost or you can come pick it up at Westfield Doncaster.
PM me or Text me on 0434970678
Power FC Sold, Mirror Cover Sold.
Here are the remaining item.
AVCR Update - just realised when I packed everything up in the AVCR box that I have misplaced the solenoid somewhere.. can't seem to locate it. So, I'll have to just sell this unit WITHOUT the solenoid CHEAP. The solenoid can be purchased new from Nengun or similiar sites for around Aud 120. So gimme an offer for the rest of the AVCR if you like and I'm happy to let it go CHEAP but not rubbish offer. PM me or text me 0434970678.
Also have a big bag of replacement Globes which lights up the dash and centre console for R34 Skylines. Bought the series 2 version white/blue lights from Nissan previously. Dealer is such a knob that I only wanted 1 globe but ended up having to buy a whole bag with 30 globes inside. Seeking $30.00 or nearest offer for everything I have at hand (prob 20+ globes).
  • Like 1
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
