So i've been having having problems with the car going into limp mode intermittently for a couple of months, some days its really bad and sometimes it wont do it for a week at a time.
My mrs drives it mainly, -taking kids to school etc and its really starting to shit her, and thus it impacts on me.
Since it started happening i've swapped out the pedal tps, the throttle body, (both with known working ones) put a new battery in and wiggled and unplugged shit etc, dit the pedal poition and throttle body relearn stuff, but still get the same problem.
I've searched a lot and it seems to be a common problem but had anyone found a definitive fix?
Oh yeah I've also cleared the drain hole under the battery and dried out all the stuff, (fuse box etc around there)
-Rod
https://www.sau.com.au/forums/topic/457051-m35-stagea-p0121-throttle-problem/
So you have a TPS fault, something is wrong with the tps signal back to the ecu. There are two tps signals and they are both monitored/compared by the ecu constantly and anything that may throw the voltages out, even slightly will trigger the limp mode.
Do you have anything else hanging off the TPS wires? Such as a cruise control, piggyback ecu or something else aftermarket?
Yeah I punched out the drain tube.
However the error occurred 3 times again today.
After being good for a few days. I don't know what to do now!
I've got a whole other car for parts so I might just keep swapping things. Starting with that whole fuse box, and maybe the ecu.
My mrs said it seems to rev up more than it should just before it throws the error. And it's always after stopping at an intersection or something and when she gets back on the accelerator it does it.
It sounds like a problem with the throttle potentiometer going high or low just off closed but it's been swapped with one from the other car that was fine
Plenty of times, either the throttle resistor on the back of the pedal, or the throttle itself is likely the issue, unless you have a wiring fault between them and the ecu.
What codes are the ecu throwing? Is it only the P0121? That seems to relate to the pedal sensor.
When the throttle goes into limp mode it almost disables the throttle. It will sit on 1200 revs, enough to drive out of problems and get off the road. You can actually get more throttle out of it if you push the pedal all the way to the floor, but it is quite dangerous, especially as it happens randomly.
Yeah that's the only code, and having tried the pedal assembly and throttle body from the other car that never had a problem I'm suspecting a wiring issue, corrosion, dry joint, or ecu problem, I'll swap the ecu and fuse box out over the weekend and pray that fixes it. It was strange that it worked flawlessly for 3 days after changing the relay so maybe there is a wiring problem in the fuse box.
What locally sold car has the same throttle pot? I vaguely remember reading it was a Maxima but can't find it again...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
