Hey guys, i've got a R34 GTT, thats running a rough and i've got no clue as to how to fix it. Its your standard Rb25 Neo, but with aftermarket intercooling tubing, a pod filter and a HKS G176 BOV, recently i've changed the oil, sparkplugs, rocker cover gaskets and half moon seals.
Firstly on a cold start, it starts up and idles perfectly, but when re-starting it up ( Warm start ) the car won't continue to run and will only run if I hold the accelerator on for 5-10 seconds at 1000-1200 RPM.
Secondly sometimes when I'm accelerating at a normal speed, i hear popping sounds from the engine bay and I loose a considerable amount of power. The only way that i've been able to overcome this issue is by revving the engine over 4000rpm and then it goes away after a little. I also get this same issue at the top end of my revs, its almost like i can accelerate to a certain point and then it begins to pop. Its like the engine can go harder but is being stopped by something.
Thirdly, My check engine light comes on after about 5-10 minutes of driving. My dad and I found that my turbo had melted my O2 sensor wires, and still after re-wiring it, the check engine light still comes on, so I have no clue as to what to do with that.
And lastly i was wondering if its normal in turbo cars to get oil on the inside of your inter cooler / turbo / intake tubing. There is a decent amount oil along the sides of the tubing that's got me worried.
Any help would be appreciated, Cheers.
https://www.sau.com.au/forums/topic/457096-r34-gtt-engine-problems/
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
