Hi all,
Rewiring my fuel pump with a relay to suit a Walbro 460l but have ran into some problems..
It's wired as follows
On the relay terminal 30 goes to the battery via 8g wire
Terminal 85 goes to the chassis
Terminal 86 is from the old fuel pump wire (the side going to the fuel pump controller)((the trigger wire))
Terminal 87 is going to the fuel pumps positive wire.
The pump is earthed directly to the chassis.
Problem is the car turns over but won't fire. I can hear the fuel pump priming. It only runs when using the original positive wire on the pump
I have tried using different relays
Disconnecting the fuel pump controller
I even ran a wire directly from the battery to the fuel pumps positive just to see if it would start... And it wouldn't
The previous owner had wired the pumps earth directly to the body
Any help appreciated!!
https://www.sau.com.au/forums/topic/457218-32-gtr-fuel-pump-rewire/
edit**
Seems yours is wired the same.
Are you sure it is the fuel pump priming and not the attesa pump you are hearing?
It doesnt make sense that it will work with the original wire and then not through the relay.
Have you checked the terminals on the relay after you have switched the ignition to reds? By that I mean go to pin 86 make sure you have your pump signal then go to 87 and check to see if power has come through.
this is very weird.
maybe post some pictures
Cheers for the reply,
Yeah pin 86 gets power for a couple seconds after flicking the ignition on.
Pin 87 has power for a couple seconds also after turning on the ignition, I can heaR the pump and have checked with a multimeter that it's getting 12v through the relay
Something else is stopping it from firing...
Ecu is Nistune.
Something that needs to be double checked:
The polarity on the pump. Don't be embarrased if you get it wrong. From memory the black wire is positive on the fuel pump or something weird.
If the polarity is reversed it will sound like it's running but really it's going backwards and the car won't fire
The earth is attached to the chassis whether the pump is powered via relay or the original wire so polarity must be correct.
I did think the voltage going to terminal 86 might of been too low to turn the relay on (pump is getting 9.4v when the car is idling) hence why I tried with the pump connected straight to the battery.
Cheers for the replies!
Edit: I have a feeling the wiring has been messed with further up the harness
Edited by 33SOM
I don't like having a relay operating the FPCM operating another relay, simple is best.
So I'd use the ecu Pin 18 as my trigger. (Pin 18 goes to ground to activate the pump)
My relay would have:
Relay 85 to Pin 18 of the ecu.
Relay 87 to positive feed for the fuel pump.
12V+ in to Relay 30 and looped to Relay 86.
That's how its wired with the exception of the "red wire" being yellow/black in the 32r
I have tried a narva and a bosch relay with no luck.
Bypassing the relays it still wouldn't start..
The 'red wire' is not the yellow/black one that is earth. The power wire is white/purple. This is the case in 32 gts-t anyway I imagine it would be the same in GTR.
I think it's different. From memory there was a brown/white and black wires
My experience with re-wiring has been with re-powers where there's no problem cutting into a harness, and I haven't touched my GTR so if my info isn't right feel free to correct.
To me Mr Nissan has already done the job for you.
For the positive feed, you just have to install larger cable to the fuel pump relay and of course larger cable from relay to the pump.
On the negative side of the circuit, the FPCM etc can all stay where it is, simply supply the pump with a larger cable chassis ground.
I believe the fuel pump relay for a 32 GTR is behind the centre boot trim. You should find 2-relays, one is fuel pump the other is ATTESSA.
Cheers for the replies.
I have tried with the fpcm hooked up and disconnected.
I also tried using the trigger wire before the factory fuel pump relay to trigger my relay
I tried switching polarities. The pump just blew a fuse.
As stated earlier the pump directly to the battery running at full noise still won't get the car started.
Positive wire on a 32gtr is 100% black/yellow. I pulled the pump out to confirm..
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
