G day people I have a 98 gtt only owned it 2 months so I know nothing about these things starts fine idles fine but when I put the hammer down any where from 3500 to 5000 the power will drop out completely.. I thought it blew up .. But still is running... If I drive around just normally it's ok will only drop out when it feels like it have changed the fuel filter thought I might ask before I take it to the shop .. Standard intercooler and turbo 3 inch exhaust k&n air filter cheers
https://www.sau.com.au/forums/topic/457364-gtt-r34-engine-miss/
Hmmmm... I don't think anyone has ever tried anything other than oem coilpacks.
You know modification of r34's never really took off so I don't think there would be very strong aftermarket support for these cars.
Same on why there isn't much info about squeezing power out of them on the net.
great stuff. it's good practice to gap your plugs down to 0.8mm as well. Fresh coil packs should be firing no problem but reducing the gap makes it a bit easier on the ignition system.
you can buy pregapped plugs - BKR6E or BCPR6ES. Don't get the ones with -11 suffix, those are 1.1mm gap (and unfortunately more common). The ones without the suffix are 0.8mm.
you can put platinums/iridiums in if you get a good price but copper plugs are cheap and although you have to change them a bit more often it's good to have a look at them now and then (spark plugs tell a story about how your engine is running.. rich? lean? detonating? you'll see it on the plugs).
  • Like 1
Say what?!
if they have -11 at the end then all you have to do is gap them down to 0.8.
If they are the same heat range as what is required then it makes zero difference!
I have gotten spark plugs that were meant to be gapped at 0.8 but were all over the shop, 0.7 - 1.0 on a batch of six
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
