Hi Guys & Gals,
Been a while since I've been on SAU and I thank everyone for keeping it alive, I've researched a lot of the information posted on this web site to help me acquire a PM35 Axis direct from Japan. Without the ease of access to the abundant amount of info my task would be daunting to even think of purchasing a vehicle over seas without an inspection/test drive etc,let alone which version or model would suit my needs/desires.
So here's my new addition, as stated PM35 Axis 3.5L RWD with 97,000km with options and aftermarket trinkets I want already on the car. Waited a while for this particular one to pop up for grabs.
post-32983-0-14978900-1436783923_thumb.jpg post-32983-0-21148200-1436783971_thumb.jpg post-32983-0-15903900-1436783997_thumb.jpg
After cruising her around for a few weeks I'm finding that all my boxes are being ticked off for what I'm looking for in a car and with an inspection done on a hoist she's mechanically sound with just a few cosmetic items to address.
Many thanx goes out to the lads at Import Monster ( Aaron & Rob ) as well as Northshore Prestige ( Ben ) for assisting in the acquisition & compliance of the Stagea. Everyone involved was extremely helpful.
Look forward to catching up with more Stagea owners to see what they have conjured up with their pride and joy, as well as go for a cruise.
Regards Jase.
  • Like 2
https://www.sau.com.au/forums/topic/458201-my-first-stagea-im-impressed/
Welcome to the club, good to have another PM35 around.
If you're not already, check out the 2 following fb groups as well.
https://www.facebook.com/groups/296526673815644/ - NSW Owners Club
https://www.facebook.com/groups/17462900896/ - Owners & Enthusiasts
welcome back, and sorry you chose a 35 over a 34 :P
do you still have the cima too?
Hey Duncan, still got the Y31 Cima & R31 Silhouette but may have to let one go but can't decide, we will see. Hope to catch up soon matey. ;)
Thanks Sam, will check it out :) .
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
