I'm not a panel beater by any means but i don't think it's completely gone
That said, could be cheaper to buy a 2nd hand one and have it painted because those supports along the corner are also bent which may be hard to fix due to it being alloy as you've mentioned
  • Like 1
Anything can be saved really. It is true aluminium is harder to work with for normal smash repairers.
the cost is going to just come down to how long it takes to repair and paint.
I would estimate definitely around the cost of a second hand bonnet.
(spray painter)
I'll go against the grain. I don't think it can be saved at all.
IS that 2 cuts through the aluminium or just a serious crease?
If by chance it can the Cost of repair and paint will exceed the cost of buying 2nd hand and paint.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
