Hey. There was a person at the auto salons that Supercharged his Skyline. Its a waste of money. He spend soo much money putting in a supercharger and got the power of a stock Gts-t (140Kw). Might as well just buy a stock GTs-t, will be quicker and cheaper.
Chris
https://www.sau.com.au/forums/topic/45882-superchargers/#findComment-932999
As a very general rule of thumb, supercharging is good for down low, but useless up high (and turbos are the reverse).
Basically there is no particularly good reason to supercharge a Skyline, in fact many would argue its an inferior technology (including the man who designed the supercharged-6 used in Holden's Commodore).
LW.
https://www.sau.com.au/forums/topic/45882-superchargers/#findComment-933039
Before making your mind up read these threads:
http://www.skylinesaustralia.com/forums/sh...ht=supercharger
http://www.skylinesaustralia.com/forums/sh...ead.php?t=44169
http://www.calaisturbo.com.au/showthread.p...ghlight=rb30esc
Look for warpspeed's posts, he has some opinions and (more importantly) experiences that are vastly different to those expressed above.
https://www.sau.com.au/forums/topic/45882-superchargers/#findComment-933172
from what I have seen and read the older type of blowers on the old V8s and stuff, the roots and screw type are pretty inefficient. But the the more modern centrifigal type ( vortech ) are a lot lot better in design. Very similar to a turbo in fact. They drain a lot less from the crank to operate as well.
As an example my friend supercharged his 3.2l V6 rodeo. When stock it had 76rwkw. They strapped a vortech V1-s trim @ 10psi to it. It hit 200rwkw at 6500rpm and the curve was still climbing hard but they backed off because the engine would have let go if revved any harder. This gave him incentive to do a full engine rebuild. He upgraded to the T-Trim and its now making 385rwkw @ 25psi and they havent sorted out a few little gremlins that are keeping it from 400. The drivers and the cars maiden 400m pass yielded an 11.9 sec pass on slicks that had not been warmed up properley.
https://www.sau.com.au/forums/topic/45882-superchargers/#findComment-935253
i went to a place near me to get a quote on supercharging my r33 gts, for a custom setup including front mount and all the shit they wanted $12,000 Hahahahahaha
he said it would have made 200 rwkw (currently 107rwkw)
but that isnt an option as selling my car plus that 12 grand (so all up about $24-26,000)
that would get me a besat of a gts-t.
before i went in there i thaught that it would cost like 5-6000 to do it.
James.
https://www.sau.com.au/forums/topic/45882-superchargers/#findComment-935486
Chris,
300rwkw isn't cheap.
Unless most or some of the mods are already there to support it.
To get 300rwkw in a GTST from dead stock you are looking at a minimum of $7000-8000.
Because I've built another motor its more in the vicinity of almost 15k. :rofl:
But ahh well its all for my enjoyment.
When My other half says 'Your not going to get your money back'
I say.. 'I'm not doing it to get my money back.'
I looked in to it for my VS 5ltr Commodore before I sold it.
It was going to cost around 7-8k to get only just over 200rwkw.
I was told that to get more power from there I was going to have to start opening up the engine + a different trim etc.
It is expensive to do it properly.
https://www.sau.com.au/forums/topic/45882-superchargers/#findComment-936818
Also, considering supercharged skylines arn't exactly common, the workshop would pretty much need to do all R&D work as well.
There is a big difference in labour between fitting bolt on parts and having stuff custom built for an uncommon application.
Also, depending on what was included in the $12k it might not be that bad (think management & tuning, exhaust, IC, labour etc).
https://www.sau.com.au/forums/topic/45882-superchargers/#findComment-936890
Given a choice of spending $3000 or more on the car, why not go for the tried end proven method. I know that for that muchmoney I can get a stock GTSt to 250ish rwkw, but when it comes to superchargers its a lot more of an unknown.
There is nothing wrong with walking the less troden path, but be prepared to pay the $
https://www.sau.com.au/forums/topic/45882-superchargers/#findComment-938514
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
