MAD MT 4 - interest and vote for date
Me thinks cruise :burnout: then piss-up :Party: is a better order than piss-up ;) then cruise :spew: . For the one reason, Sunday morning follows real close behind Saturday night. Is hung over people in skylines driving stupid(fun) a good idea?
Just my observation.
  • Replies 62
Originally posted by BiteMe
I am in any of those days now
Car finally fixed
6 sheared bolts in the manifold and 3 sheared bolts by the turbo
All done by Gavin wood Auto TEch
Only problem now is, that I picked up car in the morning and now I am @ work :)
Another one.. I'm going to keep tally now.
