FOR SALE:
BNR 32 (R32 GTR)
1989 Model,
Approx 85K K’s
5 Speed Manual
Mods include:
• 3” Trust Exhaust from the turbos back.
• Greddy Strut Brace
• 17” VOLK GTP RIMS
• HKS POD Filters
• HKS Turbo Timer + ¼ Mile Timer etc.
• Aftermarket FMIC
• Kenwood Head Unit + 10 CD Stacker
The car is Gun-metal grey in Colour and is in BEAUTIFUL condition throughout…. I’ve just had the car serviced by ADVAN using Motul Oil etc.
I have to sell the car 1. To get rid of some debt and 2. Because I will have to go into Hospital for surgery soon and will not be able to drive for up to 3 months following…(as you can see it’s a waste having a GTR sitting there for 3 months!)
At the moment the car only gets driven on weekends and most of it’d driving is done on the freeway between Hornsby and Newcastle.
The Car is registered till March 2005 so there’s plenty of Rego there.
I am asking for offers around the $30,000.00 mark but, obviously, the price is negotiable (serious offers only)….
Also, as a side not, I don’t take kindly to tyre kickers or joy-riders (I’m sure you understand…)
If there’s anything you’d like to know, that I didn’t post up, please feel free to email me at: [email protected]
Cheers.
Dave.
https://www.sau.com.au/forums/topic/45902-selling-my-gtr/
  • Replies 69
Also, as a side not, I may consider trading for something a little cheaper with cash adjustment (something that's not gonna break my heart to have it sitting there for a while); I am considering getting a MZ20 Soarer (Manual 7M-GTE) or a Cefiro so that I can start getting into a bit of drifting once I'm back on the road....
Cheers guys,
Dave.
https://www.sau.com.au/forums/topic/45902-selling-my-gtr/#findComment-935728
Sorry I havn't been on for a bit....
Not really interested in an integra thanks jomsy.... I've owned the car since February, I had it up for sale when I first got it 'cause I had the 2 cars at the time (but i put the price too high for any one to show interest). Then the GTS-t sold so I didn't worry about selling the GTR (YAY!!!) but now i've found out I have to go back into Hospital so I have to sell her (DOH!!!).
Sorry man, Don't have any log books, there where none there when I got her. I have a feeling the belt has been changed but I couldn't say for sure or not....
Cheers guys,
Dave.
https://www.sau.com.au/forums/topic/45902-selling-my-gtr/#findComment-941060
guys i checked this car out on the weekend its a nice! condition gtr...
- original paint that is immaculate
- drives smooth and tight
- suspension nice and firm
- revs cleanly and pulls hard :P
only mild breathing mods like exhaust/intercooler/pods
id be buying it if i wasnt still selling mine, mid range torque and traction is amazingly different to my old gts-t :headspin:
someone buy it :)
thanks,
dave
https://www.sau.com.au/forums/topic/45902-selling-my-gtr/#findComment-981778
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
