I've just got a modified standard ECU put in my car.
I've been umming and ahhing about the Greddy emanage and other things but the opportunity to put this in just came up so I went for it.
It's got the limiters taken off it and I dunno what else. Details are a bit sketchy. So far I have noticed that the power delivery is so much smoother than before. I think it's because before the standard ECU was constantly making corrections due to the higher boost.
I would say that the seatofthepants-o-meter is registering a 10-15 kw gain which isn't a lot but the new smoothness means that it feels, and should be, faster. When you floor it in 2nd (or any other gear for that matter but I want to keep my license) you are not sitting at peak power the whole time. By getting rid of the tiny little hesitations as the standard ECU corrected and re-corrected it gets to redline faster. I've hit the rev limiter in 1st gear twice now by accident which I normally never do. (bad me)
So boost cut is gone, speed cut is gone (yay for the Eastern Creek straight) and it only took about half an hour to learn my driving habits and give the extra power over.
Beauty is that the Nissan consult can still be plugged into it and the trannie has no issues whatsoever. I presume I'm going to blow up my diff now.
https://www.sau.com.au/forums/topic/45928-info-for-gtt-tiptronic-owners/
Abo Bob,
you legend, I have been doing lots of research and I couldn't get a straight answer on whether or not it would really work, it seemed the only other option is a SAFC2 which seems outdated now.
What other mods do you have, what boost were you and are you running now?
I have FMIC, 3" exhaust and dump pipe, pod filter, boost at just under 1 bar (14/15psi). I am getting a bit over 150rwkw which seems low due to mods but I seem to be running very rich, I am told that the emanage (excluding ignition harness which I am told won't work on the autos) should give 30-40rwkw if I run 17/18psi when the boost cut is changed? What are your thoughts? Do the R34 turbo's cope with this amount of boost? or does the nylon wheel melt?
Also, as AFRO asked, what did it set you back, and where did you get it done.
Cheers
Cost me a grand as an exchange from Powerplay but it's a bit of a one off at the moment. Give them a call in a few weeks or about a month and mention my car (they know it).
Hunter - That does seem low. I had 162 with less boost. I have Nismo panel filter, CES split dump/front pipe, 3" cat, Fujitsubo cat back which is fairly quiet and an AVC-R for boost.
Just went out for a blat and turned the boost up to 1 bar just to see. Seemed to cope fine although the turbo seemed to be surging a little. I think that's because I don't know how to adjust the boost duty cycle on the AVC-R.
If you consistantly run 1 bar something in your turbo will let go so I'd stick to 0.85 if I were you.
ok,, umm i dunno if this is meant to be correct or not,,
but i got mine dynoed ,, and i was getting 177rwkw, and mine is stock!
except exhaust,,,, standard boost and all,, even down to the factory air filter,,
but it was running a bit crap lately and ecu has error's 17 & 46,, might get it dynoed again,, to make sure everything is running ok,,
it was dynoed in shootout mode,,
edit:- mine is manual,,
AFRO
Abo Bob,
Did you get all the harnesses put in, ie ignition etc... or just the fuel component? I am still considering getting the whole emanage kit and I am assured by Advan (the Trust distributor) that all the components work with the 34 auto and the coil frying problem has been addressed with the latest sw revision.
Now that you have been running with it for a little while is it still running well, is the auto box coping ok? Feeling any faster? I am told one would expect around 40-50 rwkw, what do you think?
Cheers
I don't have the emanage. Advan need to get their story straight. I've been told by one of them there that it will work fine but that you can't use the ignition harness and by another that he "doesn't recommend putting it in there at all."
I have a modified standard ecu.
So far I would say that I'm a little concerned about the auto's power handling abilities. The flaring that I used to get between 1st and 2nd gear when cold only now seems to need to more warming up to work properly. If I redline it however, it drops timing or something, does a little fart out the back and kicks into 2nd beautifully.
I'm going to look into changing my fluid.
Good to hear there is something else out there....the second I get another e-manage ignition harness though I'll put the diodes in and give you guys the details....hoping to get a harness next week...unless one of you guys has one laying around you could sell to me?
Yeah the flaring is easily sorted by a good warm-up....once the car hits temp you don't ever get it.
There are 2 problems with the EManage in autos, the first is the coil frying problem, but that happens to manuals as well. The real problem is it removes the ECU control over ignition on gearchanges, this means you end up with very jerky gearchanges. Plus, with no power cut, the gearbox will wear much faster. Simplkistically this is because the EManage has no gearshift logic.
I believe there may be a cure for problem #1, but I don't see anyway for problem #2 to be overcome with the current logic.
So I am looking forward to your results. :D
how did they do it abo bob? modified standard ecu for skylines. thought that was impossible as no one worked out how to do it properly or am i thinking of r33 gtst when it comes to chipping the ecu?? SydneyKid, help.
if not looks like il be having a chat to powerplay in the not to distant future...
probably a daughterboard.
the japs have been doing it for ages for the 34.
yeah the ecu requires a new chip, the in the 32s you can just download to the existing eprom but the 33 and 34s require a seperate chip.
  • 3 weeks later...
Well I just did a dyno run to find out the following:
1. 189.4 rwkw at 0.8 bar which is up from 162 rwkw at 0.85 bar before the ECU.
2. I'm not sure how to read air fuel ratios. It's between 10.9 and 11.65. Which is leaner?
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
