Hi all,
Have some bits off my R32 GTR for sale. Located Western Sydney 2766.
RB26 plenum and throttle bodies - $450
SRI carbon fibre triple gauge holder, little paint chip on top [RRP $129] - $100
Apexi ELII triple gauges (Boost, water temp, oil temp) w/ control box, wiring [RRP $700] - $450
Radiator hose with ARK Design adaptor and temp sensor - $80
R32 GTR front strut brace painted wrinkle black - $75
Blitz full auto turbo timer $80
Drift boost T - $30
https://www.sau.com.au/forums/topic/459434-assorted-bits-and-pieces-syd/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
