it connects from the outlet side of the stock cooler to the throttle body / plenum
air pipe -> afm -> turbo charger -> piping -> cooler -> piping -> throttle body -> plenum
xxxxxxx -> xxx -> xxxxxxxxxxxx -> xxxxxxx -> xxxxxx -> pipe in red is here -> xxxxxxx -> xxxxxxx
https://www.sau.com.au/forums/topic/45954-please-help/#findComment-934826
Are you referring to the pipe that has the "Air Inlet" or "Vacuum hose"?
I thought you mean the larger "Air Inlet" hose
If Air Inlet: it goes the throttle body / inlet plenum
If Vacuum Host: it looks like it goes the boost controller, will get a pic of mine tongiht from rb25det
https://www.sau.com.au/forums/topic/45954-please-help/#findComment-935402
no problems. on my rb25det there is a small tube running to the intercooler piping which goes to the throttle body. the small tube you are talking about goes the the factory boost solenoid. Im not sure how and why its such a small tube and yet it manages to control boost to 7psi (lacking knowledge of air pressure stuff) but thats where it goes
will try nad get a pic tonight or tomorrow
https://www.sau.com.au/forums/topic/45954-please-help/#findComment-935588
are you using a boost controller?
if not, you put a 6mm hose from that nipple directly to the wastegate. if you are using a BC its a little more complicated. and yes, you must have a pressure signal for the wastegate so you'll need to put one in your pipe. hybrid kit i bet isn't it?
-rb25
https://www.sau.com.au/forums/topic/45954-please-help/#findComment-935627
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
