Hey ppl late last yr I brought anther 4 door R33 which is an auto. This one had an wolf ecu in it. Which has been put into my other R33 4 door which is a manual. Ok I swapped my manual ecu and put it into the auto car. The car ran like a dream for ages bout 4 months.Then revease and 1st went bang.Bugger! So I got anther 4speed automatic and a S1 auto Ecu.The problem is the car runs like crap. It nearly stalls when slowing down and surges at times. Why would this be? What's coursing this problem. As a test i even put the manual Ecu back into the car and ran fine.Anybody know what the problem is? Thanks.
https://www.sau.com.au/forums/topic/459696-auto-r33-s1-ecu-problem/
it could simply be a bad ECU, try another one? or even simpler, that the auto one was not plugged in correctly?
There are also some differences among models for how the ECU power is supplied so maybe make sure it is the right ECU (check part# via FAST)
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
